Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
WTB Mad Dat brake booster bracket
datutemad
Posted on: 2007/6/12 12:33
After a mad dat brake booster bracket if any one has a 2nd handie they would like to sell just let me know. Or even if any one knows a good way of fitting the booster with out the bracket I would be interested in your info.
#2
Re: WTB Mad Dat brake booster bracket
WARDY
Posted on: 2007/6/12 12:37
Im pretty sure u can just drill the extra required holes and bolt the sucker to the firewall... thats what i am doin anyways
Unless someone tells us any different..
#3
datutemad
Posted on: 2007/6/13 11:13
Thanks for your info wardy. Are you going to do a ca conversion or just upgrading the brakes. the reason I ask is because the mad dat booster bracket also accommodates for a hydrulic clutch set up too which is needed for the ca conversion. If you do end up fitting the booster or have an alternative for the clutch let me know.
#4
WARDY
Posted on: 2007/6/13 13:36
No probs mate
Yeah i am doin a CA conversion.. Most ppl use a Toyota AE86 ( sprinter ) clutch m/c. I have also heard of ppl using datsun 1600 ones and a few others.. Easiest way ta mount it is to make sure its in the right place lol.. use a holesaw to cut the hole bigger where it mounts to the firewall, mark and drill the holes for the studs and bolt it on.. u will most proberly have to shorten the rod to mount it to the pedal.. Then its a matter of makin up ur pipes
#5
WARDY
Posted on: 2007/6/13 13:37
Oh and try and try it again ta make sure it clears the engine!! nothin worse than goin ta fit ur engine and it hits
