« 1 ... 9 10 11 (12) 13 14 15 ... 21 »
Re: A-Series Manifold Templates for Autocad - Come n get 'em
From Adelaide, SA
Sorry guys - been caught up with work and haven't got quotes yet.
Bare in mind that the bulk buy for turbo manifolds will include a flange so you needn't order one of these.
I will be quoting them anyway, along with the inlets and the 40mm weber flanges.
Mid next week - I promise!!!!
Posted on: 2007/6/8 14:32
From Coondle, WA Australia
Rally1200 I:2 E:2
Dattoman_1000 I:2 E: 2
dattodevil I: 1
pager I: 1 E: 1
Beattie E:1 (steel)
Cable_tie I: 3 alloy 2 Mild E: 5 (all Oval)
LAGWAGON: I: 1 E: 1
boofhead: I: 1alloy 1steel E: 2 (oval ports)
Grunterhunter I: 2 E: 1
Tnpshow I: 1(MS) E: 1
ang94541 I: 1alloy oval, 1steel oval E:3 rally1200 style
Ianey I: 1 alloy 1 steel E: 1
Sidedraught 2x mild steel exhaust
kue1000 I:1Alloy E:1 steel - oval
1200Rallycar I: 1 alloy 1 steel (oval ports) E: 2 steel
Wombat Racing 1 ovalport inlet, 2 exhaust
Teretonga I: 3 alloy (oval ports) E: 3 steel
Dundee1000 1 alloy oval, 1 Steel exhaust.
picko: 2 exhaust, 2 intake
Trickdat I: 1 alloy 1 steel (oval ports)
reuby_tuesday I : 1 E : 1 oval port steel
Posted on: 2007/6/8 15:43
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Adelaide, SA
UPDATE
Righto - FINALLY an update.
Files are here (AutoCAD 2004):
40DCOE Flange
Oval Port Exhaust Flange
Oval Port Inlet Flange
Prices are below in AUD (rounded to the nearest 5c) and are based on the number of interested parties so far:
10mm Aluminium Inlet Manifold Flange $31.30 ea
10mm Mild Steel Inlet Manifold Flange $10.60 ea
10mm Mild Steel Exhaust Manifold Flange $10.30ea
8mm Aluminium 40mm DCOE Weber Flange
Qty of 5 - $18.85
Qty of 10 - $14.30
Qty of 20 - $12.00
8mm Mild Steel 40mm DCOE Weber Flange
Qty of 5 - $9.75
Qty of 10 - $8.15
Qty of 20 - $6.95
POSTAGE
Ok - to work out postage, I've employed the help of the Australia Post Website:
AUSTRALIAN ADDRESSED PARCELS CLICK HERE
INTERNATIONAL PARCELS CLICK HERE
Weight of each item is APPROXIMATELY:
Exhaust Flange - 900gms
Alloy Inlet - 300gms
Mild Steel Inlet - 900gms
DCOE Mild Steel - 400gms
DCOE Alloy - 140gms
Dimensions are approx (I've added a bit to the dimensions to account for packing):
Inlet: 300mm x 110mm
Exhaust: 400mm x 110mm
DCOE: 170mm x 110mm
I can work out postage for everyone and post it here if that's easiest.
Alternatively, if it's cheaper, a 3kg satchel for $9 can be used.
Local Pickup for the Adelaide boys can be either Devon
Park
during business hours or Belair after hours.
PAYMENT
According to the list, there is just over $1200 worth of orders here (not including postage either) so I will probably need full payment in advance or at least a
sizeable deposit (goods won't be shipped until full payment is received).
I will PM my bank details for direct deposit once the list is finalised.
To the US/international guys - which is the easiest way? Paypal?
ADDITIONAL NOTES
Ok. Please note that some machining of the flanges may be required to match your head exactly.
During the design period I have compared the designs on many A series heads with some varying results.
It seems the castings are not to critical on tolerance.
Hence I have made all ports close to standard factory size (little bit bigger).
Also, once fabrication is done, you may need to remove the brace on top of the inlet manifold - it MAY foul on your rocker cover.
CURRENT LIST OF INTEREST
Please check this and adjust accordingly so I can get final numbers:
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
Beattie E:1 (steel)
LAGWAGON: I: 1 E: 1
Posted on: 2007/6/14 0:59
From Sydney
oww im in for 3 alloy inlets and 3 steel exhaust..if thats cool???
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
Beattie E:1 (steel)
LAGWAGON: I: 1 E: 1
Curtis: 3 Alloy inlets, 3 Steel exhaust
Posted on: 2007/6/14 2:57
From Perth
Tell me where to send the money and its done
Rally1200 I:2 E:2
Dattoman_1000 Inlets alloy x 2 Exhaust steel x 2 DCOE alloy x 2
dattodevil I: 1
pager I: 1 E: 1
Beattie E:1 (steel)
LAGWAGON: I: 1 E: 1
Posted on: 2007/6/14 5:52
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
Beattie E:1 (steel)
LAGWAGON: I: 1 E: 1
boofhead: I: 2alloy E: 2steel (oval ports)
Posted on: 2007/6/14 6:24
From The garage, NZ
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
Beattie E:1 (steel)
LAGWAGON: I: 1 E: 1
Cheater_5: 1 mild steel inlet, 1 mild exhaust
Posted on: 2007/6/14 6:40
From Adelaide, SA
Bump for those who may have missed the update.
I will be PMing bank details and final costs to people shortly!
TC
Posted on: 2007/6/16 2:29
From Portland OR. USA
Ill jump in an get a set.
Gary
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
Beattie E:1 (steel)
LAGWAGON: I: 1 E: 1
Gary_P: 1 alloy oval port intake, 1 mild exhaust
Posted on: 2007/6/16 2:50
From sydney
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
Beattie E:1 (steel)
LAGWAGON: I: 1 E: 1
Posted on: 2007/6/16 6:35
