#11 Re: What Shocks?!
short-coupe Posted on: 2007/6/18 10:10
wet kit, as in oil, not a gas insert? like forks on a motorbike, no way you can put 2/3 oil in a strut then try and install a gas insert.
#12 Re: What Shocks?!
Curtis Posted on: 2007/6/18 10:16
lol no no 2/3's the way up with the strut installed so only like 50m's or watever. Its just normal installtion method for regular insterts. remeber gas insert still use oil as per normal ones theres just gas in them aswell(insted or air) so the oil dosent bubble up as easy.
#13 Re: What Shocks?!
WhiteSedan Posted on: 2007/6/18 10:17
Inserts can be gas charged or oil, or oil with gas assist.
With my konis, which are oil inserts, I put 150ml coolant in with the insert to help with heat transfer.
#14 Re: What Shocks?!
short-coupe Posted on: 2007/6/18 10:31
150ml, do you have short inserts in your strut?
« 1 (2)
