what gear box???
From Toowoomba, QLD
Im wanting to get a 5 sp for my a12 but im not to sure whats the best to put in.
Can anyone help??
Posted on: 2007/6/19 1:32
Re: what gear box???
The best one is the japan-only GX-5 5-speed.
Posted on: 2007/6/19 1:38
From Toowoomba, QLD
is there a good common one?
i know that the celica 5 sp can be fitting but i've been quoted 2 n half g
Posted on: 2007/6/19 1:41
From Toowoomba, QLD
will a stanza 5 sp work
Posted on: 2007/6/19 1:42
From Geelong, Vic
technically a stanza 5 speed could be made to work....but first you need to find the really common(every one wishes) 63a sunny 5 speed then use its bell housing....but as you would have to find the 5 speed a series box first its kinda pointless
Posted on: 2007/6/19 2:06
From Toowoomba, QLD
so what should i be looking for?
is the celica 5sp the only option i have besides search for a needle in a hay stack
Posted on: 2007/6/19 2:29
From Adelaide, SA
Firstly, read up HERE
Secondly, be prepared to pay $800 upwards for a 5 speed IF you can find one.
The Celica conversion MAY be cheaper if you buy the bellhousing from Dellow and source/fabricate the rest yourself.
Posted on: 2007/6/19 2:44
From Sydney
2.5 Grand for the Toyota split case 5 speed sounds like a rip off, unless the 5 speed has been completely serviced and rebuilt.
Dellow kit is ~$800 AU
Toyota 5sp ~ $250AU - $500 [i sure some may find them cheaper]
Misc ~ $300AU machine flywheel, clutch etc GB mounts.
Posted on: 2007/6/19 2:48
From Toowoomba, QLD
righto thanks guys you have been a big help
Posted on: 2007/6/19 3:45
