#1 mods for 120y
todro Posted on: 2007/6/20 10:21
ive just bought a 74 120y for $100 with 105000 genuine kays no rust, is great! any way just wanting to know wat sort of mods i ca do to get a bit more power out of her with a budget of $1500~
#2 Re: mods for 120y
WARDY Posted on: 2007/6/20 10:25
100 bucks?? bargain haha
Mate with that cash i would get.. 32/36 Downdraught weber, extractors/exhaust and electronic ignition... then if u had some left over get a cam.. but that is a little harder to install..
good luck mate..
Wardy
#3 Re: mods for 120y
gino_120y Posted on: 2007/6/20 10:55
throw in an A15 with a mild street cam, with a weber carby as mentioned
i would get the electronic ignition and the exhaust last.
might be able to get it done for close to $1500
#4 Re: mods for 120y
todro Posted on: 2007/6/20 11:01
cheers thanks wardy i had a good read of your 1200 built up over on riverinacars
#5 Re: mods for 120y
WARDY Posted on: 2007/6/20 11:35
riverina cars?? where are ya from mate?? we have a new forum runnin now www.streetmodified.com.au join up!! haha
#6 Re: mods for 120y
todro Posted on: 2007/6/20 11:43
yeah i just signed up to it aye, im also from wagga, btw where did you get your front guards and bonnet from
#7 Re: mods for 120y
dazzasute Posted on: 2007/6/20 14:34
You might ALMOST squeeze an L series in for around that much, if you can get the bits cheap enough, and have a little know how...
L series engines getting pretty cheap these days
Radiator
gearbox
tailshaft
crossmember (there's one that virtually bolts straight in)
gearbox crossmember...
better stop spreading evil ideas...
#8 Re: mods for 120y
WhiteSedan Posted on: 2007/6/20 14:37
L-series evil is good evil.
#9 Re: mods for 120y
beattie Posted on: 2007/6/20 14:38
you could do a simple suck thru turbo setup for that much! Or sell the 120Y and get a nice 1000 hahahahaha
#10 Re: mods for 120y
PIGDOG Posted on: 2007/6/20 14:40
ill second the L series motion EDIT, ok ill thrid the motion then
find your self a rusted out 180b and go to town, swap crossmember lower control arms struts and stuff over
the L series will pretty much bolt straight in, clutch master lines up perfectly with existing studs in the firewall
pretty sure there are some other gearbox mounts under the car for the l series too
