Re: What sway bar to use with CA18?
Rear shocks are koni reds with reset leaves with a leaf added. No rear swaybar but from reading, many don't think they are necessary.
The car balance would be very nose heavy like any CA conversion. Brake balance is definitely not the problem. I've got about 3 degrees of negative camber on the front and it turns in really well with no understeer at any stage through the corners.
It's also got a minispool diff which should encourage understeer but it's really quite neutral.
B110 SSS - point taken about public forums but I am appropriately qualified to filter through the rubbish.
The ride height is actually quite low
Posted on: 2007/6/21 8:30
Subject Poster Date
     What sway bar to use with CA18? Daveman 2007/6/21 2:29
       Re: What sway bar to use with CA18? Jake77 2007/6/21 3:27
         Re: What sway bar to use with CA18? Daveman 2007/6/21 3:47
       Re: What sway bar to use with CA18? B110SSS 2007/6/21 5:26
         Re: What sway bar to use with CA18? Daveman 2007/6/21 5:48
           Re: What sway bar to use with CA18? boofhead 2007/6/21 8:09
           Re: What sway bar to use with CA18? DattoSunny 2007/6/21 8:18
             Re: What sway bar to use with CA18? Daveman 2007/6/21 8:30
               Re: What sway bar to use with CA18? sooty_grunter 2007/6/21 9:32
                 Re: What sway bar to use with CA18? Daveman 2007/6/21 11:49
                   Re: What sway bar to use with CA18? Mildman 2007/6/21 12:06
                     Re: What sway bar to use with CA18? Daveman 2007/6/21 12:13
                       Re: What sway bar to use with CA18? Mildman 2007/6/21 12:14
                         Re: What sway bar to use with CA18? boofhead 2007/6/21 12:40
                         Re: What sway bar to use with CA18? Mildman 2007/6/21 12:41
                           Re: What sway bar to use with CA18? matty 2007/6/21 12:48
                             Re: What sway bar to use with CA18? boofhead 2007/6/21 12:53
                               Re: What sway bar to use with CA18? matty 2007/6/21 13:00
                                 Re: What sway bar to use with CA18? boofhead 2007/6/21 13:07
                                   Re: What sway bar to use with CA18? matty 2007/6/21 13:10
                                     Re: What sway bar to use with CA18? Daveman 2007/6/21 13:41
                                       Re: What sway bar to use with CA18? PIGDOG 2007/6/21 15:16
               Re: What sway bar to use with CA18? B110SSS 2007/6/22 2:05
                 Re: What sway bar to use with CA18? Daveman 2007/6/22 3:34
                   Re: What sway bar to use with CA18? B110SSS 2007/6/22 4:51
                     Re: What sway bar to use with CA18? Daveman 2007/6/22 7:03
                       Re: What sway bar to use with CA18? boofhead 2007/6/24 9:47
           Re: What sway bar to use with CA18? B110SSS 2007/6/21 8:27
