Re: What sway bar to use with CA18?
From Sunnybank, Brisbane
im using a 1200 sway bar, i went to the trouble to get the bigger tougher 120y swaybar, but it doesnt fit past the sump. if u put em next to each other its very decieving but they dont fit.
Posted on: 2007/6/21 9:32
Subject Poster Date
     What sway bar to use with CA18? Daveman 2007/6/21 2:29
       Re: What sway bar to use with CA18? Jake77 2007/6/21 3:27
         Re: What sway bar to use with CA18? Daveman 2007/6/21 3:47
       Re: What sway bar to use with CA18? B110SSS 2007/6/21 5:26
         Re: What sway bar to use with CA18? Daveman 2007/6/21 5:48
           Re: What sway bar to use with CA18? boofhead 2007/6/21 8:09
           Re: What sway bar to use with CA18? DattoSunny 2007/6/21 8:18
             Re: What sway bar to use with CA18? Daveman 2007/6/21 8:30
               Re: What sway bar to use with CA18? sooty_grunter 2007/6/21 9:32
                 Re: What sway bar to use with CA18? Daveman 2007/6/21 11:49
                   Re: What sway bar to use with CA18? Mildman 2007/6/21 12:06
                     Re: What sway bar to use with CA18? Daveman 2007/6/21 12:13
                       Re: What sway bar to use with CA18? Mildman 2007/6/21 12:14
                         Re: What sway bar to use with CA18? boofhead 2007/6/21 12:40
                         Re: What sway bar to use with CA18? Mildman 2007/6/21 12:41
                           Re: What sway bar to use with CA18? matty 2007/6/21 12:48
                             Re: What sway bar to use with CA18? boofhead 2007/6/21 12:53
                               Re: What sway bar to use with CA18? matty 2007/6/21 13:00
                                 Re: What sway bar to use with CA18? boofhead 2007/6/21 13:07
                                   Re: What sway bar to use with CA18? matty 2007/6/21 13:10
                                     Re: What sway bar to use with CA18? Daveman 2007/6/21 13:41
                                       Re: What sway bar to use with CA18? PIGDOG 2007/6/21 15:16
               Re: What sway bar to use with CA18? B110SSS 2007/6/22 2:05
                 Re: What sway bar to use with CA18? Daveman 2007/6/22 3:34
                   Re: What sway bar to use with CA18? B110SSS 2007/6/22 4:51
                     Re: What sway bar to use with CA18? Daveman 2007/6/22 7:03
                       Re: What sway bar to use with CA18? boofhead 2007/6/24 9:47
           Re: What sway bar to use with CA18? B110SSS 2007/6/21 8:27
