Re: why do you need an internal and external fuel pump?
From NSW, Australia
Well im not 100% sure about internal and external fuel pump i thought it was based on your fuel tank. As all EFI cars have one or the other. What im running is a lifter pump, like something that you would use on a webber engine. This fills up my surge tank, then a high pressure efi pump feeds the engine via a fuel pressure regulator. I am also running larger fuel line.
Im sure you all know what im talking about espically anyone with a surge tank.
Posted on: 2007/6/26 12:55
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Subject Poster Date
     why do you need an internal and external fuel pump? frankthedolphintrainer 2007/6/26 10:30
       Re: why do you need an internal and external fuel pump? LittleFireyOne 2007/6/26 10:34
         Re: why do you need an internal and external fuel pump? frankthedolphintrainer 2007/6/26 10:35
           Re: why do you need an internal and external fuel pump? LittleFireyOne 2007/6/26 10:38
             Re: why do you need an internal and external fuel pump? 120fly 2007/6/26 10:55
       Re: why do you need an internal and external fuel pump? BigD 2007/6/26 12:55
         Re: why do you need an internal and external fuel pump? ddgonzal 2007/6/26 16:38
           Re: why do you need an internal and external fuel pump? Dodgeman 2007/6/26 16:47
       Re: why do you need an internal and external fuel pump? onetwo00 2007/6/30 15:03
