Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
race harness on ute
SLUG1200
Posted on: 2007/7/2 10:40
hi everyone.
just wondering who has done race harness and seats in a 1200 ute and how did u do it. where are ya supposed to bolt the harnesses to?
#2
Re: race harness on ute
WARDY
Posted on: 2007/7/2 10:46
Yeah i have also wondered about this.. most of the utes i have seen wit harnesses have been fitted with a roll cage..does anyone kno if there any way of bolting them to the floor behind the seats reinforced with some hefty flat??
#3
PIGDOG
Posted on: 2007/7/2 11:00
i think they have to be on an angle no greater than 45 degrees to the floor....so you would have to have it bolted down in the tray if you arent having a rollcage
#4
ca18det_man
Posted on: 2007/7/2 11:03
The harness needs to be attached to rollcage directly behind the seat. It cannot be attached on any more than 45degree angle?? You think if its staight down and you have a crash the seatbelt is going to squish you down and compact your spine. This is the only way i have seen it done for a rally 1200 ute. The harness will have to pass through the rear steel section. there wouldnt be any room to have a rollcage inside the cabin .
Cheers Andrew
#5
sssute
Posted on: 2007/7/2 13:44
I run my harnesses straight to to rear panel behind the seat, and then it is bolted through into the large ally section that my hard top attaches too.
