How to fix wheel alignment problem
My 1200 has been pulling to the right for some time now. I finally got tired of holding the steering wheel to the left to compensate.
My solution was to change the front tires. There was a vibration from the front wheels, so when I went to check them out, I discovered one of them was out-of-round. It happened on a highway trip a few months ago.
Anyways, after new tires (see my avatar) the alignment is perfect once again, without touching caster, camber or toe-in! Also the vibration at 50mph/90kph is gone. That reminds me that one of the first things the alignment man does is check the wheels for runout and inspect the tires.
Posted on: 2007/7/4 20:08
Re: How to fix wheel alignment problem
From Townsville, Qld
interesting, I've just been dailing in the angles and copping some nasty wear
Posted on: 2007/7/4 21:49
