HELP with anti dieseling solinoid wire
From southern sydney "the shire"
the anti dieseling soilinod is rooted in my 120y, i have a few other carbies so ill just see if any of them work, but to change it do i just unscrew the old one and screw the new one in? or is there a gasket or an O ring or anything that i should be careful of or that i should look for before i do this?
any help/info would be great.
thanks Simon
Posted on: 2007/7/9 14:45
Re: changing the anti dieseling solinoid
From Perth WA
just a re-useable copper washer. make sure you put it back on or else it will leak fuel! you can put a new one on but not really necisary!
Pretty straight foward job, just unplug, unscrew(19mm from memory), take pin and 'housing' off and renew!
Posted on: 2007/7/9 14:48
Chris...
ah ok thanks beattie
Posted on: 2007/7/10 0:17
turns out the solinoid is fine. its wasnt getting any power. but my next question is, the yellow wire that connects to the solinoid, is it quite a thick wire? because there is another yellow wire that goes to the temp sender. i think that i could have swiched them by accident once and i need to know which wire is for which.
so i have swapped the 2 (big wire on solinoid) and now the temp guage doesnt work.
can someone help me?
Posted on: 2007/7/10 1:47
