#1 Upgrade engine mount rubbers???
Tyrie Posted on: 2007/7/6 7:20
Just found I broke an engine mount rubber, standard 120Y item. I was going to go grab a b310 rubber and stick it in but no-one in canberra has them in stock, and if I have to wait to get one I might as well get something better.
So I was wondering what people have used that has the same bolt size, and is the same height or SHORTER than the original. I have a kelpro cortina rubber on the other side but it is taller than standard.
Part numbers would be best but make/model is good. cheers
#2 Re: Upgrade engine mount rubbers???
reuby_tuesday Posted on: 2007/7/6 12:41
Tyrie
PhunkDr and i discussed a similar problem a while ago.
This link
should give you some ideas.
edit : a http://datsun1200.com/modules/myalbum/photo.php?lid=4129link
to the sketch that I drew to describe what I was on about.
#3 Re: Upgrade engine mount rubbers???
PIGDOG Posted on: 2007/7/6 15:05
cortina ones????
arent they all the rage
#4 Re: Upgrade engine mount rubbers???
Tyrie Posted on: 2007/7/10 12:14
yeh I have a cortina one in the other side, it is a good 10mm taller than the standard 120Y mount, and I feel that using one on the other side would put the engine on more of a lean.
I like the idea of the bolt though, I'll give it a go.
cheers
#5 Re: Upgrade engine mount rubbers???
WhiteSedan Posted on: 2007/7/10 12:46
A bloke around the corner from me has Jag V8 ones in his 1200, he reckons they are similar to the cortina ones but not as tall.
#6 Re: Upgrade engine mount rubbers???
woody Posted on: 2007/7/10 16:21
i wouldnt mind knowing what type of jag v8 ones go on and if they were a bolt on because mine are about to break soonish
p.s. sorry for the quick hijack
#7 Re: Upgrade engine mount rubbers???
dats-me Posted on: 2007/7/11 6:52
i broke 1 in my 120y not long ago and i got a replacement one from repco for like 20 bucks. that was just a stock one im not sure if you are after another stock one or a stronger one not though
#8 Re: Upgrade engine mount rubbers???
A14force Posted on: 2007/7/11 6:54
RB20 ones are pretty close. You need to open up the holes a few sizes, and fold down the rolled edge on the xmember.
