Re: brake booster troubles
From melbourne VIC
hey pigdog,
i had the same problem with the booster i brought off you!
the pedal was realy sort and the brakes would lockup without any force,
coming off the pedal and the bosster would get stuck and make a loud click.
gave me the ####s until i got another 1 from the wreckers, which doesn't work either now
and yes, the reaction disc is at the end of the booster pushrod.
might be a faulty return spring
good luck sorting it out
Posted on: 2007/7/12 7:48
Subject Poster Date
     brake booster troubles PIGDOG 2007/7/10 15:01
       Re: brake booster troubles BigD 2007/7/11 3:50
         Re: brake booster troubles datosun 2007/7/11 5:22
           Re: brake booster troubles PIGDOG 2007/7/11 5:52
             Re: brake booster troubles R-fastmotorsport 2007/7/11 7:12
               Re: brake booster troubles b310gx 2007/7/11 10:51
                 Re: brake booster troubles PIGDOG 2007/7/11 11:05
                   Re: brake booster troubles gino_120y 2007/7/12 7:48
                     Re: brake booster troubles PIGDOG 2007/7/12 7:59
