Clutch conversion for a ca18det ute
From Adelaide
Hey guys
wondering wat set up u used for the hydrolic clutch converison??
yes i tryed searching but i cant find anything..
i member sumone saying to use a pintara set up??
is there any bolt in ones?
eg: no shortning the shaft..
cheers, Ben
Posted on: 2007/7/2 6:36
Re: Clutch conversion for a ca18det ute
From perth airport
maddat sell one
Posted on: 2007/7/2 6:53
From Bris-Vegas
I drilled some holes in the firewall & fitted a Pintara master cylinder.
Easy & cheap.
Just needed some extra bracing to the steering column.
Posted on: 2007/7/2 7:35
CA18DET '74 1200 ute project
From Adelaide
With the pintara sleave.. it is the right lengh?
or does it need cutting down??
Posted on: 2007/7/12 8:14
From Mudgee NSW Australia
Hey coops how close is the clutch master cylinder to the inlet manifold? the master cylinder looks as if it would be pretty close.
I have mine right beside the brake master cylinder a lot shorter and its still close.
Cheers Andrew
Posted on: 2007/7/12 10:34
If In doubt run more BOOST
From Adelaide
I think that the pintara master will hit the inlet manifold on the CA As ca18det_man suggests. It needs to be short and small to clear.
Scott
Posted on: 2007/7/12 13:07
From Perth Western Australia
One for sale on ebay:
ebay
I'm gonna try NIS15L's (I think thats his username, PRO18T on datnet) method using a girling claypipe master cylinder reverse mounted under dash with a remote filler in the engine bay. Check his photo album for a pic.
Posted on: 2007/7/12 17:16
From Adelaide
this is one of kev rowleys conversion, so it does work
Posted on: 2007/7/13 2:26
From Bris-Vegas
Yeah, it's close alright, but it just fits in behind the plenum.
About 20mm clearance.
The Pintara clutch master has a big chunky aluminium reservoir that's integral with the M/C.
If I was doing it again, I'd leave a bit more space by using the Skyline M/C with the small plastic reservoir.
Posted on: 2007/7/15 23:23
