Re: brake upgrade
From Brissy
looks like im going to the wreckers tomorrow with a tape measure...lol
Posted on: 2007/7/12 12:36
Re: brake upgrade
From Geelong, Vic
and you will find nothing that you want looking at datsuns and nissans
try toyotas as most of them have the same bearings
every datsun/nissan hub that i have seen that will go onto stanza struts is the same offset wheel wise, its only disc offset that has changed
but toyotas, coronas and such, use the same size wheel bearings....cant remember if they had more or less offset though
Posted on: 2007/7/13 1:36
Re: brake upgrade
From Brissy
cheers pigdog
i have heard 260z hubs are shorter??
Posted on: 2007/7/15 1:56
Re: brake upgrade
From Geelong, Vic
but they carry a different disc centre bore and most likely different disc mounting pattern
Posted on: 2007/7/16 5:55
Re: brake upgrade
From Brissy
ra40 celica hub brings it in 10mm but still not enough..
Posted on: 2007/7/17 8:12
Re: brake upgrade
From Brisbane
are any of you getting radius scrub problems with R31 struts? or are you running RCA's to help the problem?
Posted on: 2007/7/17 8:17
« 1 2 (3)
