Re: question about oil blockage. any ideas would be a great help.
From Adelaide, SA
no there was no hole, i got a new head gasket and drilled a hole and it seems oil is comming through now. i just need to double check the valve clearences as there is still alot of ticking.
Posted on: 2007/7/15 23:45
While you're at it, check to see if there is damage to the poshrods & adjusters at the rockers & also have a look at the rocker to shaft clearance.
If the engine was run without oil to the rockers for very long, then it's possible that these parts may be damaged, & if so, then repair by replacement would be the go.
What head gasket did you use?
Posted on: 2007/7/16 0:02
Love your Datsun.
Treat it well.
From Adelaide, SA
could the ticking be caused by worn/ damaged valves etc. and i got the gasket from repco.
Posted on: 2007/7/16 9:23
From Adelaide, Australia
Cool you didnt sell my old coupe!! Hows it going? More head problems?
Posted on: 2007/7/16 9:27
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Adelaide, SA
yer still got it had brake probs so didnt sell as it was ####ed. got them fixed and tried to change head now running into more problems. hopefully i can sort it out. dont even know if i solved the oil problem
Posted on: 2007/7/16 9:31
Start her up (not for very long) without the valve cover on, you should see oil come out of the rockers.
Posted on: 2007/7/16 9:38
IPRA Build
From Bendigo, Victoria, Australia.
any head will click after u have taken it off.
check (by doin what whitesedan said) that u ahve oil up there now and then if u do take it for a good spin around the block.
if ticking persists conmsult your doctor
Posted on: 2007/7/16 11:24
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From Adelaide, SA
does anybody have a picture that would show were the oil should be comming from there are lots of little hole across top op rocker but it seems more to be comming out of the two bolt looking things that are next to the head bolt. excuse my lack of not technical language
Posted on: 2007/7/16 15:04
From PORTUGAL
If this can help :::
HEAD VIEW
Posted on: 2007/7/16 20:12
The Worst it Looks - Bigger The Challenge ...
From Adelaide, SA
i think i need to try that whole starting it up without cover on and have a closer look
Posted on: 2007/7/16 23:15
« 1 (2) 3 »
