« 1 (2) 3 »
Re: new catch can
From Melbourne AUS
looks good to me!
i like the quick release connection, very race !
Posted on: 2007/7/17 10:33
1973 B110 A12
Re: new catch can
From Canberra
have you got like a return line to the sump or at least a drain valve? or do you have to pull it out and empty it when its full? Or just hoping it never gets full...
Posted on: 2007/7/17 10:47
Re: new catch can
From SE Melbourne
Yeah I'm wondering how you'll empty it without spilling it!
Posted on: 2007/7/17 10:52
Mildman, Datsunless
Re: new catch can
From South Africa, Bloemfontein
Thanks to boofhead who mailed me the pictures a while back, I will be making the same type of one for myself. Not for track use but just for looks.
Mine, I will however make a small modification at the bottom end in the centre by putting a small sprinkler system tap thingy of plastic to drain yearly.
Will also post a pic when done.
Great and cheap idea that works.
Just read about the 2litre recuired for CAMS rules. 2 litre is quite big can. The catch can will almost be the size of the A12 motor.
Posted on: 2007/7/17 11:03
1977 Datsun 1200GX
Re: new catch can
can we up date those stickers to say ive got a sprinkler system? and guts?
so you thought it was your engine ticking, must be the sprinkler in stead.
tsk tsk tsk tsk ....... tsktsktsktsk....
nah does the job, but will the pvc stand up to 100deg c plus of hot oil for long?(my only concern but will hold onto it longer than no pvc pipe)
Posted on: 2007/7/17 12:19
Re: new catch can
hmmmm, you have a point there.Boofhead will have to let us know.
Posted on: 2007/7/17 13:31
1977 Datsun 1200GX
Re: new catch can
From Geelong, Vic
the oil wont stay at that temp for long...and its not like there will be huge amounts of oil spilling into it
Posted on: 2007/7/17 14:22
Re: new catch can
From gold coast QLD.
CAMS require a 2 litre catch can for engines up to 2000cc and a 3 litre catch can for engines over 2000cc. I do have to say i love the PVC unit,highly inventive and practical.I would not be concirned about oil temp(a series) it does'nt get that hot and if it does you've got bigger problems to worry about.Finally you 1200 guys,spare a thought for us B10 owners trying to find a spot for a bloody great can in our tiny space
Posted on: 2007/7/17 23:25
Re: new catch can
Not too shy to talk
From londonderry/penrith
i think its a great idea for a street car but a little worryed about the heat the will come off the exhaust after about 3 to 4 hot laps of it melting
Posted on: 2007/7/18 0:19
Re: new catch can
From Brisbane, Australia
my old coupe had a 90mm pvc catch can mounted up near the passenger side headlight. I made it 2l capacity. you can sort of see it here - well part of it anyway:
best thing to do is fill the catch can with stainless steel wool wrapped in a stocking to help separate the oil from the air while preventing any swarf getting into the engine. also not best practise to have the breather entering at the bottom of the can.
it was in the car for years without any problems from hot oil.
Posted on: 2007/7/18 0:36
« 1 (2) 3 »
