CA18 conversion
From Midway City, California
CA18 to go into my dat
so im new to this what other parts will i need?
really apreciate the help
Posted on: 2007/7/18 4:11
if it was easy to restore, they would call it chevrolet
don't piss off America, or we will bring democracy to your country
Re: CA18 conversion
From perth airport
its a lil expenseve that motor or maybe its realy low kms ?
youll need a diff new brakes a bigger gearbox tunnal a new fule tank a crossmeber to suit
thats a start for ya
Posted on: 2007/7/18 4:19
Re: CA18 conversion
From Townsville, Nth Qld
CA18DET
<=== or search bar on left
hope these help
Posted on: 2007/7/18 4:22
Cheers
Davo
Re: CA18 conversion
They probably are a bit more expensive over there because they are less common. However, I'm always skeptical when someone covers something in tyre shine when selling it because you know it's been cleaned and you can't tell where leaks etc are.
Posted on: 2007/7/18 6:06
Re: CA18 conversion
From perth airport
wd40 makes most motors look great
Posted on: 2007/7/18 6:10
Re: CA18 conversion
From SE Melbourne
Tailshaft
New diff?
Fuel pumps/surge tank/fuel lines
New front suspension?
Make sure you have the wiring for the knock sensor (not in the main EFI loom)
Intercooler and radiator....and piping for both of those too.
Accelertor cables, hydraulic clutch, speedo cable, gearbox crossmember.
That will get you started....
Posted on: 2007/7/18 13:31
Mildman, Datsunless
Re: CA18 conversion
From Adelaide
With your conversion, i do a lot of components to make it a more simple. If you check out www.maddat.com.au there should be some gear that might help you out.
Cheers Scott
Posted on: 2007/7/18 14:48
Re: CA18 conversion
From SE Melbourne
I can tell you the threaded sleeves I got from sssute are top class too, I can only assume all his conversion parts are as classy!
Posted on: 2007/7/19 10:06
Mildman, Datsunless
Re: CA18 conversion
From Adelaide
Thanks Ben.
Posted on: 2007/7/19 10:40
Re: CA18 conversion
From Adelaide
i can second that for the maddat products..
i have also brought hydo clutch set up, throttle cable, dump pipe.. and also buy engine conversion kit..
A++
Posted on: 2007/7/20 10:01
