Browsing this Thread:
1 Anonymous Users
Re: 9 inch diff quote wat u think?? |
From Townsville, Nth Qld
Quote: Turboute wrote: Quote:hey mark u talkin bout joshh he running 10's? He wishes. no its mark bourne
k thought so, was chattin 2 josh n he has a sweet set up but didn't think it would run 10's EDIT - lol perthute just high jackin ur forum sorry bud
Posted on: 2007/7/18 5:22
Cheers
Davo
From perth airport
well ill see how long the standard h160 ? diff lasts .. how goodis the lsd in a r31 diff for example my 180sx when drifting it loves two wheels but after a while the diff gets hot and start braking out in to one leggers does this happen wit the r31 ??
and i would think haveing a heavy diff would help the handeling snice the weight is down low ?? and utes are too light at the bak ??
Posted on: 2007/7/18 5:34
u lookin at track use r ya?
Posted on: 2007/7/18 5:35
Cheers
Davo
From Geelong, Vic
dont know about how good the r31 LSDs are....they do wear outafter a while if you are constantly giving them a hard time and if it starts one wheeling stop straight away, i dont think you can kill an LSD much quicker that holding a one wheeler(thats once the clutch packs wear out)
my sedan doesnt handle to bad with the r31 diff, apparently i should have crappy handling with all the extra weight of the L series and stuff
will make the ride a bit harsher due to the unsprng weight increase
Posted on: 2007/7/18 5:39
Quote: PIGDOG wrote: dont know about how good the r31 LSDs are....they do wear outafter a while if you are constantly giving them a hard time...
i agree but same can b said 4 anything really... all depends on treatment n maintenance
Posted on: 2007/7/18 5:53
Cheers
Davo
From Canberra
standard r31 LSDs will not last if you do nuts. I was quoted $400 drive in-drive out to rebuild my r31 LSD as tight as I wanted. Better option though would be to get a kaaz lsd or similar. Or get a lokka, they sound wicked driving around normally
Posted on: 2007/7/18 5:54
From Geelong, Vic
what ever you do dont put an open centre in....just plain boring at least i can drift when turning left
Posted on: 2007/7/18 5:58
hey Tyrie,
how much strain ur R31 Diff under?
Posted on: 2007/7/18 5:59
Cheers
Davo
From perth airport
davo ill be doing a bit of everything drag to street to drift not shore how well the ute will go conpaired to the 180sx at drifting pigdog yea my 180 only slips after a lot of punishment but some guy from silvia wa recon i need a ls2 diff not shore wat it is must be stronger ? my father has a xy 351 wit 9 inch and it gets punished a lot and all ways get two wheels
and i dont like lockers they are fun but seem to harsh
Posted on: 2007/7/18 6:00
From Canberra
nah I meant a "lokka" its kinda like a spring loaded locker, goes clunk clunk clunk around corners, then locks up as soon as you give it some. Theres video of a VL with one somewhere, pretty impressive and about $600 I think edit: dattodave I dont think my car could break a h165  but it has been known to do some nuts which buggered the LSD.
Posted on: 2007/7/18 6:09
