Browsing this Thread:
1 Anonymous Users
Re: rear sway bar. |
From Brisbane, Australia
Quote: datsun_guy wrote: Yeah its had the rear leafs re-set also shocks done by a pro and the frong has been re done with ajustable tops with ajustable strut brace. Also have 13 by 5.5 all around. And i want it to handle a tad better.
handle better? that's too vague to know if a rear bar will help it handle better. if you are trying to reduce understeer, then yes it will help. if its not really understeering now, then you might only make it handle worse by introducing too much oversteer. Or if you want to reduce the amount of bodyroll in total, you will have to increase the roll resistance at both ends either with springs, shocks or bars. Quote: datsun_guy wrote: Also is there any thing that i could to do to aviod the horible axle tramp i have.
1. check condition of all bushes first. 2. check condition of shocks 3. have pinion angle checked by a suspension specialist. can be adjusted with wedges. 4. if none of that works (it really should unless you have heaps of power), have the leaf pack revised with a reverse half leaf on top of the pack.
Posted on: 2007/7/18 3:50
From sydney
Your spring guy can put in a short stiff leaf on the top forward part of your spring pack that will fix the axle tramp.
Posted on: 2007/7/18 3:54
but if that's all you do you might just be treating the symptom rather than fixing the problem. if everything is in good condition and set up properly, you shouldn't get axle tramp unless the springs simply can't handle the torque being put through them.
check the other things first.
Posted on: 2007/7/18 4:02
From sydney
Or you can try JohnTaylors "tricky springs".
Posted on: 2007/7/18 4:05
From Canberra
datsun_guy the grille on my 120Y is just a late model one, pretty common. I have the front of my 120Y sitting on low king springs and stadard replacement 180B shocks I believe. The rear is standard height with some commodore shocks. 20mm front swaybar. When going into corners I can turn the wheel and the car just ploughs foreward until it loses enough speed then turns the corner. I'm running about 2-2.5deg neg camber but it stll scrubs the hell out of the outside edges of the tyres. Can this be fixed by changing components or am I just going too hard into corners? I believe the rear "roll centre?" may be too high causing the understeer? The rear is damn high when braking into a corner... heres a pic:
Posted on: 2007/7/18 5:44
From Geelong, Vic
some smaller profile tires and a reduction in ride height should do it some good
so in short you have understeer when entering corners tyrie
my 1200 was understeering rather bad, changed tires and added some camber....say hello to oversteer, maybe its just coz i moved the old tires from the front to the back
Posted on: 2007/7/18 5:51
From Canberra
yeh understeers entering corners. It still understeered entering corners when I put 205/50s on the back (from 225/50) but then had oversteer out of corners.
Posted on: 2007/7/18 6:06
From Sydney
Tyrie, this is my car at the same corner at Wakefeild about 5 years ago.
Posted on: 2007/7/18 6:10
From Sydney
I run koni sports up front with 275 lbs kings. No rear bar
Posted on: 2007/7/18 6:11
From Geelong, Vic
hahahahaha just sitting a bit flatter
Posted on: 2007/7/18 6:12
