« 1 (2)
Re: how to make cheap elec dizzy!
From Christchurch, New Zealand
I got a whole engine for free, they're quite common in NZ, the bottom end is similar looking to the A15, from memory the number is on flat section near the fly wheel
Posted on: 2003/3/24 10:36
From sydney australia
michael,the quick way to tell the n12 dizzy is if it has a condensor on the side,it's points,if it has 2 wires running to the coil,it's electronic.they aren't common,but not too rare at the same time,if you know what i mean.
Posted on: 2003/3/25 11:42
From Melbourne, Australia
oh well too late now
although i could use one on the a-15
gee i love having two driving cars and i havent even picked it up yet
this bloke i met is gonna be damn handy when i need to build a motor, his head is full of wonderfull information which he is more than happy to share on the might a-series
Posted on: 2003/3/25 11:53
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Canberra, Australia
Would this be the same dizzy as the Et pulsar had?
I might be able to find a few of those lying around a friend's house...
Hmm... no more points... would be good....
Posted on: 2003/3/25 14:11
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From auckland, new Zealand
matt is it just as easy as taking the top plate of the points dizzy off and putting the top plate on from the E15? it cant be can it?
Posted on: 2003/3/26 4:20
Yes, in fact being the rough bugger that i am i just tacked it on with the mig!
Posted on: 2003/3/26 8:22
Temporarily to see how it would go! I've never touched it since!
Posted on: 2003/3/26 8:23
From Warwick, QLD
hey matt, what did ya do about the magnets that go on the dizzy's shaft?? Did the E15 have a collar on it and you just used that or.....???
Cheers
Damo
Posted on: 2003/3/26 13:48
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Yes from memory the whole top shaft assembly just fits straight in. The top shaft with the rotor etc is seperate to enable the advance to work. It all just slips together nicely (again from memory, its a while ago and as stated earlier it has always performed well)
Posted on: 2003/3/29 9:57
« 1 (2)
