#11 Re: Starter motor upgrade with high comp??
cheater_5 Posted on: 2007/7/24 2:59
well i called up a mate who races a series/1200's and asked what he uses.
He still uses the 1200 a12 starter motor as its the lightest lol but with a huge earth strap and reconditioned.
I would never have thought it would have the guts to do it but i guess i'll have to pull the starter and make it all shmick
#12 Re: Starter motor upgrade with high comp??
sycodat Posted on: 2007/7/29 15:12
hay cheater 5
#13 Re: Starter motor upgrade with high comp??
cheater_5 Posted on: 2007/7/29 15:18
ummm yes ???
#14 Re: Starter motor upgrade with high comp??
dattodude Posted on: 2007/7/29 15:23
Just park it on a hill and clutch start it. Only wimps use a starter motor.
#15 Re: Starter motor upgrade with high comp??
sycodat Posted on: 2007/7/29 15:26
the gear reduction are not that dear I paid $45 at the weakin yard it still had the bloody price tag on it
#16 Re: Starter motor upgrade with high comp??
sycodat Posted on: 2007/7/29 15:30
I wuold like to see you start one the little turds on the flat dattodude Quote:
#17 Re: Starter motor upgrade with high comp??
sikdatto1200 Posted on: 2007/7/29 16:07
or set up your starting system so you can crank it with no ignition and once its spinning fast fick ignition on and away it goes
#18 Re: Starter motor upgrade with high comp??
TnPshow Posted on: 2007/7/29 20:27
That's actually really easy to do using the stock ballast resistor wiring.
#19 Re: Starter motor upgrade with high comp??
sycodat Posted on: 2007/7/30 5:44
ant that the truth
#20 Re: Starter motor upgrade with high comp??
cheater_5 Posted on: 2007/7/30 14:09
thanks for the input guys.
Mostly to sycodat though, you've got real insite to the problem
« 1 (2)
