« 1 (2) 3 »
Re: 4x 15 "subs in a 1200 ute
well what would you use for kick ass system
Posted on: 2007/7/24 10:50
go hard , go quick , see yaaaa
does he have the guts
yes I do unfamilia
Posted on: 2007/7/24 10:57
From Adelaide, SA
in a ute a good deck some six inches (max 6x9's) and a small amp willl be all you need it only a small cabin.
Posted on: 2007/7/24 11:14
thanks man,
Posted on: 2007/7/24 11:44
From Coondle, WA Australia
Thats the thing with a ute. Bieng such a small cab,means yo dont need monster setups to good sound and volume, which is handy since you dont usually have much space.
If you want to use a sub with splits, invest in an active sub tube. bazooka make a good unit and for compact bass, its the only way to go. I have an older bazooka sub tube in my ute (extd cab patrol) and its heaps. I run 6 inch splits straight from the deck, and its fine.
My brother also has a bazooka sub tube that he bought 2nd hand about 10 years ago and its still cranks despite bieng significantly abused. His is a passive unit and it has outlived three amps now from memory.
Posted on: 2007/7/24 11:55
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From perth airport
i have 2x 400w amps 2x6inch splits 2x 12subs in a 1200 ute it sounds realy good
Posted on: 2007/7/24 19:31
From perth airport
Posted on: 2007/7/24 20:14
From Canberra
My bit of advice for car audio would be that you get what you pay for. If you buy $70 sony Xplod speakers they'll sound as cheap as the price. If you're willing to spend a little more you'll notice the difference!!!!
Posted on: 2007/7/24 20:33
From NSW, Australia
Geez, perthute we can hear you comming from here in Sydney Thats like a undercover tool box. So do you use a torno cover or an open tray?
Im thinking of a nice split/tweeder combo with some mid range should do the trick. a small amp, then to fine tune with a graphic eq.
But currently im fine tuning the engine,
Priorities first !!.
Posted on: 2007/7/24 21:03
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
From perth airport
lol yea i have a hard cover now . and hearing loss lol
Posted on: 2007/7/24 22:12
« 1 (2) 3 »
