Re: Urgent brake help needed!! (1000)
From Invercargill, New Zealand
I haven't pulled the drums off a 1000 but on other Dattos you can use a couple of 10mm bolts that screw into the brake drum and allow you to wind the drum off over the shoes. Also try tapping the drum off toward you with a rubber or wooden hammer. Tap all around the diameter so that it clears the shoes evenly.
Posted on: 2007/7/24 21:25
Subject Poster Date
     Urgent brake help needed!! (1000) boozymcstagger 2007/7/24 21:20
       Re: Urgent brake help needed!! (1000) teretonga 2007/7/24 21:25
         Re: Urgent brake help needed!! (1000) boozymcstagger 2007/7/24 21:41
           Re: Urgent brake help needed!! (1000) teretonga 2007/7/24 22:00
             Re: Urgent brake help needed!! (1000) boozymcstagger 2007/7/24 22:13
               Re: Urgent brake help needed!! (1000) teretonga 2007/7/24 22:16
               Re: Urgent brake help needed!! (1000) Cable_Tie 2007/7/24 22:21
                 Re: Urgent brake help needed!! (1000) boozymcstagger 2007/7/24 22:24
                   Re: Urgent brake help needed!! (1000) kue1000 2007/7/24 22:59
                     Re: Urgent brake help needed!! (1000) boozymcstagger 2007/7/24 23:11
                       Re: Urgent brake help needed!! (1000) dattoman_1000 2007/7/25 0:12
                         Re: Urgent brake help needed!! (1000) boozymcstagger 2007/7/25 0:31
