« 1 2 (3)
Re: 4x 15 "subs in a 1200 ute
From Townsville, Nth Qld
dam jordan,
with that cranking through the cab u've got the Db count of a night club
all u need now is some lights, strobe,maybe some smoke... PARTY! lol
on the down side ur gonna have the hearing of an 80yr old when ur 30
but hey just means u'll have to go even louder next time lol
Posted on: 2007/7/24 22:40
Cheers
Davo
From perth airport
yea the sad thing is i hardly turn it on i like the sound of the tail pipes better
Posted on: 2007/7/24 22:52
nothing wrong wit dat... a nice soundin exhaust is like music 2 my ears anyway...
Posted on: 2007/7/24 23:02
Cheers
Davo
wasnt asking if you have guts, habib reminded me off the bboofhead stickers
when i got my ute had 8inch 3ways in the doors, plenty loud for a ute cabin.(shame they were stolen from the ute)
overkill does not make it better.
Posted on: 2007/7/25 9:21
cha ching !!!!! my 2c for what it's worth ......
a set of 6" splits in the kick panels and make up some new kick panels to angle the speakers out of the foot well area a little, then mount the tweeter up on the dash. in the doors i'd look at a pair of 6x9"s, probably only a 2way, or if you can find them a split set, so you effectively have a 6x9" sub with an independent tweeter. for an amp a 4channel as a minimum, you should be able to fit this under the seat, or ideally one with sub control to run the 6x9"s more like a sub, and then not connect in the tweeters to them if you get them as a split type.
i think this would give a good sound stage in such a small cabin ... the 6x9"s would give a reasonable bass, the 6" good clear mid and the tweeters the top end.
you'd also want to get some adhesive backed sound deadening sheets to stick inside the doors, on the door skin, behind the speaker. guaranteed you'll find all sorts of new rattles
and as stated before ... you get what you pay for
Posted on: 2007/7/25 9:41
From Tamworth , NSW
get a decent head unit, make sure it will do everything you want it to do function wise ie... ipod, bluetooth etc...
all you will need then is a decent amp, and a pair of FOCAL 6inch splits.
line the inside of the doors with dynamat and bobs your uncle.
thats all you need for some kick ass on a budget.
fcuk buying multiple amps and subs and speakers, a bloke at work has the exact setup in a commonwhore ute and it has enough bass to rattle the car and the sound is so nice you can hear the squeaky bass drum pedal on a certain album he has
Posted on: 2007/7/25 10:00
From Adelaide
im pretty sure the music you play in your car is for your ears. 4 x 15"'s is all about the wank factor. Most ppl are happy with 6x9s and splits. and i think thats the way ill be going :)
Posted on: 2007/7/25 10:20
thanks guy's
Posted on: 2007/7/29 9:45
go hard , go quick , see yaaaa
« 1 2 (3)
