« 1 2 3 (4)
Re: l16 with twin sus
From southern sydney "the shire"
You can still get yourself into trouble with a stocker, trust me.
i agree. i think with the stock engine you have to drive it much harder to keep the revs and speed up around corners which can get quite dangerous. i have a mate with a worked L20 in his datsun 1600 and when we go for a drive i have to go alot faster than him around corners just so i can keep up.
Posted on: 2007/7/26 2:28
From Wagga Wagga, NSW
PIGDOG- did u try to fit a standard 4 speed box? i hear they are harder to fit then a 5 speed my 5 speed is long and then so woohoo!
Posted on: 2007/7/26 5:19
From Geelong, Vic
yeah it was a BW 4 speed, but it would fit in my new tunnel easy
Posted on: 2007/7/26 8:18
From SE Melbourne
Probably also depends how far back against the firewall you mount the engine too, and how low on the crossmember.
I've got away with a lot with a stumpy 5 speed in my white coupe by have the engine sit as absolutely low as possible, means less hammering of the tunnel, and better centre of gravity and weight distribution.
Posted on: 2007/7/26 9:46
Mildman, Datsunless
From Geelong, Vic
mine cant really go any lower as the sump would be sitting on the drag link, and there isnt alot of sump
and it seems to be sitting about as far back as every one elses
Posted on: 2007/7/26 22:43
From Brisbane, Australia
this is the extent of the reshaping required for L series tunnel clearance
and she's mounted very close to the firewall. also mounted it as low as possible for the same reasons as mildman mentioned
Posted on: 2007/7/27 0:01
From Geelong, Vic
the bit i had trouble with was where the tunnel meets the floor, it was crumpled into a stronger shape and didnt crumple any further
also doesnt look like you could have "massaged" the bellhousing area of the tunnel much more on the passengers side
Posted on: 2007/7/27 0:28
« 1 2 3 (4)
