« 1 ... 3 4 5 (6)
Re: Front brake upgrade, any suggestions?
From Albury
Hi guys]
Just finished my Kev Rowley 180sx brake upgrade.
Brakes work great even without booster.
I can fit 13" hotwires over the brakes (just had to grind a bit off the top outside edge of the caliper.
And I can fit a 205/60/13 tyre without touching the strut.Tyre is pretty close to guard lip though but shouldn't be a problem
Cheer
Bob
Posted on: 2007/7/26 5:28
From Burbank, CA
I think the strut was shortened to match the 240SX strut insert that I'm running. Then there are RCA's on the bottom to make the geometry better.
Posted on: 2007/7/26 10:47
|||\ 81 KPB310 /|||
From southern sydney "the shire"
does this Kev guy only do these brakets for 120y struts? or does he do other datsun struts too i.e. 180b struts?
can i get his details
Posted on: 2007/7/26 20:47
From Geelong, Vic
why would you want to adapt s13 brakes to 180b struts?
go buy some VR commodore calipers, some verada discs get the disc modded to suit the datto hub then space the caliper out 1.5mm
and wow you have better brakes that will fit under 14s
i would have offered you my setup.....but its sold
Posted on: 2007/7/26 22:22
From Bris-Vegas
dats-me - You have a PM (Kev's details).
Posted on: 2007/7/26 22:38
CA18DET '74 1200 ute project
PIGDOG i was just wondering because i was thinking of doing the L series swap in my 120y including the whole 180B struts ect and i dont want to do a brake upgrade on the 120y if im swapping struts.
Thanks Coop.
Posted on: 2007/7/27 4:04
From Geelong, Vic
so when you upgrade to 180b struts, do the commodore caliper and verada disc conversion on them
Posted on: 2007/7/27 6:12
« 1 ... 3 4 5 (6)
