Re: Flakey wiring
From Coondle, WA Australia
Doing it your self, unless you are an electricky guru, is a brave project even for the most seasoned home mechanics. About few hundred dollars and much much pain if doing it on your own.
A painless wiring system can lessen the mental anguish a little and can be found on the net eaisly with a simple search. They are about $700-800 Aus for a simple kit.
Or you can pay a sparky to do it. It then comes with a warrenty, no mental anguish, no hours lost in the shed, but at a significant cost. They cost heaps cause its a complicated process to get it right. From memory, my Dad had his old hilux quoted to be rewired for about $1500 - $2000 Aus, so its an expensive exercise. I am sure that one of the auto sparkies on this site should be able to give you a much better figure than I can.
Good luck.
Posted on: 2007/8/1 0:29
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Subject Poster Date
     Flakey wiring Keith 2007/7/31 20:28
       Re: Flakey wiring reuby_tuesday 2007/8/1 0:29
         Re: Flakey wiring 1200rallycar 2007/8/1 2:25
           Re: Flakey wiring frankthedolphintrainer 2007/8/1 3:03
       Re: Flakey wiring Mawler1 2007/8/1 3:32
         Re: Flakey wiring reuby_tuesday 2007/8/1 9:08
           Re: Flakey wiring ddgonzal 2007/8/2 16:53
