Stupid question who can help
From NSW, Australia
Sorry i dont have a picture (yet) but i dont know the correct name for this. on a std 1200 above where the coil is mounted there is a little white creamic box with two wires connected to each end.
What is this thing? and whats the best thing to do? remove? modify, or relocate.
Any help would be great
Posted on: 2007/7/31 16:33
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Re: Stupid question who can help
From Perth
Im thinking ballast resistor
Posted on: 2007/7/31 17:00
From Toowoomba QLD
Yep, Balast resistor and if you still have your old points ignition you have to keep it. You can relocate it fairly simply but.
Posted on: 2007/7/31 18:10
Why do any of those things? If it's not in the way, not broken, & it still works, & you don't mention that it's any of these things, then just leave it.
Posted on: 2007/7/31 20:40
Love your Datsun.
Treat it well.
From Penrith, Sydney, NSW
Hmmm. You pose a good question dodgeman.
But i will answer your question with another.
Why have an ugly ceramic looking little box in your engine bay if it's not required or could be located elswhere???
Trav
Posted on: 2007/7/31 21:55
"If the doors of perception were cleansed, every thing would appear to man as it is......infinite"
From Adelaide, SA
It is required unless you have an ignition coil with a built in ballast resistor such as a Bosch GT40.
Posted on: 2007/7/31 21:57
From gold coast QLD.
Correct
Posted on: 2007/8/1 1:27
From South Africa
You will most definately need it.
If wanted, relocate, however be extremely careful, as these become quite brittle over the years and crack easily.
Just makes sure where its relocated, that heat doesnt affect it alot.
Jus my 2 cents worth
Posted on: 2007/8/1 1:54
Life's a bitch, so f...k it.
From NSW, Australia
Well Dodgeman the topic is called stupid question and i know what you mean, but because its old and fragile is what im THINKING of what to do with this thing. if i can modify this or remove it to benifit the way my motor runs then im interested.
so all these nice datto's i see have them just hidden??
Would an electronic dizzy also do the trick. Or is it only ignition? im confused on what it exactly does.??
Posted on: 2007/8/1 3:02
Cheers,
Big D
From NZ
Ballast restistor reduces the voltage running through the points to stop them burning out.
Posted on: 2007/8/1 3:06
