Re: mechanical expertise required
From Seattle ,WA.
I guess I should of clarified the problem a little more, sorry about that.
Yes the dist. is still in the motor & the the engine runs. I was trying to check & set the timing & just wanted to spin it while the motors running. I just can't get it to turn, it's like it's welded itself to the friggin block!
It's an aluminum dizzy & a steel block, maybe that has something to do with it.
Evan
Posted on: 2007/8/1 21:25
Subject Poster Date
     mechanical expertise required edp 2007/8/1 21:10
       Re: mechanical expertise required 1200rallycar 2007/8/1 21:13
         Re: mechanical expertise required Coops 2007/8/1 21:21
         Re: mechanical expertise required edp 2007/8/1 21:25
           Re: mechanical expertise required Ronald 2007/8/2 0:02
             Re: mechanical expertise required ddgonzal 2007/8/2 16:59
               Re: mechanical expertise required - SUCCESS!!! edp 2007/8/2 21:03
                 Re: mechanical expertise required - SUCCESS!!! 1000Coupe 2007/8/2 22:56
