what 4 door parts fit on a 2 door sedan? U.S guys please help
From Adelaide, Australia
hi guys im in adelaide south australia and i have a 1200 2 door sedan (very rare here) just wondering what parts will fit from a 4 door as we only got coups and 4 doors.
i need a new floor pan, will a 4 door sedan one fit? also are the front and rear windscreens the same as 4 doors? and what badges/chrome did the 2 doors come out with? thanx guys
Posted on: 2007/8/2 20:41
Re: what 4 door parts fit on a 2 door sedan? U.S guys please help
Most parts are the same. I think the floor pan is the same.
The front and rear glass is the same (4-dr sedan to 2-dr sedan).
For badges, see wiki - Badges
Posted on: 2007/8/2 21:41
From Adelaide. SA
Matt, The rear glass is different but a sedan one will fit. As for the badges the ones on my green one are what it came with. you can drop around sometime for a looksee if you like. all other parts exept the to of the door frame and flipper windows are pretty much the same.
Cheers. Adam.
Posted on: 2007/8/2 21:45
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
The doors from a 4-dr Sedan are completely different than those of a 2-dr Sedan. However the lower half of the coupe door (door frame and door skin) is the same as the 2-dr Sedan.
The door glass and door glass frame is unique, as is the inside door panel trim, and rear side glass. Those are the only pieces you are likely to have trouble getting.
Posted on: 2007/8/2 21:52
From Adelaide. SA
Thats what I meant... its a little hard to type and be at work at the same time. Thanks for that DD
Posted on: 2007/8/2 23:41
Peter Brock
