Re: exhaust length
From Malaysia
So, what would be the recommended diameter for A12, A14 & A15? ( assuming u r running a complete lenght exhaust system with 1 straight flow muffler at the tail pipe end )
Posted on: 2007/8/6 20:56
Re: exhaust length
From Bendigo, Victoria, Australia.
i would reccomend using a ressy aswell as a cannon muffler.
im using 2.5" with cannon and ressy and its loud and will only be good for yop end power.
2" is more that good if u want a nice street car noise
Posted on: 2007/8/6 23:38
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Re: exhaust length
From Malaysia
Errmm...and on which engine cc would your suggestion be applicable?
Posted on: 2007/8/7 0:39
Re: exhaust length
From Brisvegas, oz
i would suggest 2 inch up to 1.8lt engines unless there turboed i wouldnt go 2.5
Posted on: 2007/8/7 0:57
www.camerasplus.com.au
Re: exhaust length
From Coondle, WA Australia
my worked over a12 is running a 2" system with a high flow muffler (turbo muffler they call it). Seems to suit it fine, loud enough, and seems to let it breathe just fine. Its not mandrel bent, so the bends are probally only 1 3/4".
But for the drag car, that paint on the pipe trick is not as strange as you think. My brother also used it on his supermod (speedway car), and I have heard it before as a poor mans method for pipe length. It works good enough that spending dollars on a pro to work it out, only to find that he cuts it at the same place, a waste of time.
Posted on: 2007/8/7 3:16
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: exhaust length
From South Africa
thanks guys
thats great info
Posted on: 2007/8/7 4:24
Re: exhaust length
From South Africa
gentlemen,
imn full of questions this week
40mm suideraughts on an a worked drag a14 normally aspirated motor
what would u guys recomend the size of the ram tubes should be
is there any calculation to get the correct size or is it just trial and error
thanks
Posted on: 2007/8/7 4:28
Re: exhaust length
From Adelaide, Australia
Generally trial and error minnesh, the shorter the tube the more top end it will give, longer more torquer, just like longer runners on forklift inlet manifolds give more torque.
Posted on: 2007/8/7 4:33
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: exhaust length
From South Africa
ok this is for the ram tubes that fit in front of the carbs
and not the headers that fit on the head
is this correct
thanks
Posted on: 2007/8/7 5:09
Re: exhaust length
Correct!
Posted on: 2007/8/7 5:11
IPRA Build
« 1 (2) 3 »
