« 1 2 (3)
Re: exhaust length
From South Africa
any suggestions on what lenth for flat out quarter mile
Posted on: 2007/8/7 8:30
Re: exhaust length
From Burbank, CA
what rpm are you hitting? that has a lot to do with how the setup will go.
Posted on: 2007/8/7 8:59
|||\ 81 KPB310 /|||
Re: exhaust length
From South Africa
revs easily to 8000
Posted on: 2007/8/7 10:18
Re: exhaust length
From Taupo New Zealand
there are calculations around, search for them on google. And you will probably need to do some trial and error. This long length for torque short for power is all fine but the big gains are in pulse tuning to help force charge into the engine. This will work best at a specific engine speed and will be working in reverse ie trying to force charge out of the engine at another engine speed, you can see this as a fuel mist coming out of the carbs at certain rpm on some cars without air filters.
All the same goes for exhaust, hence tuned length headers which are a lot of work to make which is probaly why true tuned length headers are expensive and rare.
fwiw the Honsowetz bible says use 32in primaries and an exhaust pipe at least 72 in long.
Posted on: 2007/8/7 20:20
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Re: exhaust length
From Christchurch NZ
Posted on: 2007/8/7 20:53
Forced Induction!
« 1 2 (3)
