« 1 2 (3)
Re: turbo trouble
From brisbane
Sooty - There is an issue with your set up. You might have a leaking or cracked wastegate, a partial blockage of the intake piping or something similar.
A standard T25 equipped CA is very hard to keep off boost.
Maybe you should buy a T25G which is only slightly bigger but will still allow you to run bigger boost and make some impressive power. But I would check everything before fitting it to find the source of the restriction.
Regards Matty
Posted on: 2007/8/6 11:14
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: turbo trouble
From Brisbane
my t28 on my ca, 2500 rpm makes 5psi, 3000 10psi, 3500 13-14psi. the t25g was at least 500rpm earier.
Posted on: 2007/8/7 3:09
Re: turbo trouble
From Sunnybank, Brisbane
i must have a problem somewhere. cos that doesnt sound right. its a very run-of-the-mill set up i'll see what i can find.
the utes bin off the road for over a week now and i havent had a minute to pull it all apart. its hard goin back to a "normal" car as a daily, damn it sux not having power.
Posted on: 2007/8/7 23:29
« 1 2 (3)
