WANTED - Side gear out of a R31 diff or similar
From Flinders View, QLD
Gday, I am in the process of shortening a R31 diff for my 1200 ute. A mate of mine is going to shorten my axles for real cheap but he needs a side gear out of a crap diff to use as a template for the finished product, just to make sure the re-splining is correct.
I know it would be easy just to use the centre I already have but I am just putting the feelers out incase someone has a 28 spline borg warner side gear they want to get rid of
Posted on: 2007/8/8 18:20
Just trying to put the bloody puzzel back together
Re: WANTED - Side gear out of a R31 diff or similar
From Bris-Vegas
I've got an old 28 spline open centre & a auto ratio (approx. 2.9:1) ratio crownwheel that you can have for the cost of freight if you like.
It'll probably cost you between $30 & $50 for the freight though.... Surely there's a 78 series borgey at your local wreckers that you can pinch bits out of for less $$$.
EA/EB falcon + VL Commonwhore + R31 skyline.
Posted on: 2007/8/8 19:35
CA18DET '74 1200 ute project
Cheers for the offer coops. I will ring around tomorrow and see what I come up with
Posted on: 2007/8/8 19:52
I got it sorted, I am gonna whack a mimi spool in my diff so I stripped the centre I had and I am gonna use one of its side geaers.
Posted on: 2007/8/9 18:43
Ah just too late. I already stuck a mini spool in mine and already have the gears lying around.
Posted on: 2007/8/9 19:13
