Painting advice please
From Perth
Hey Guys,
I am in need of some painting advice.
I am repainting my 1200 Coupe. I have chosen my colour Mazda Phantom Blue. Before winter I stripped the roof and primered the it. I quickly found out that primer is not waterproof.
I was thinking of priming it with something like chassis black. Was wondering if I could topcoat it with acrylic.
Someone has painted it with some house paint so It looks like crap. Also I have replaced a few panels with ones from my other coupe. So I got a multi-coloured car.
Posted on: 2007/8/11 2:01
Re: Painting advice please
From Huntington Beach, California
There are some products like that you can use, but they usually require another topcoat before you can apply paint.
If you aren't going to paint it right away, ask someone at an auto paint store to recommend something you can put on there.
Some catalyzed primers will work. There is also a sealer that can be used.
I would also recommend deciding what brand of paint you are ultimately going to use. The store can also recommend a primer/sealer that is compatible with the paint. Generally speaking, it is better to stick with one brand of products so each of them will work with each other.
Posted on: 2007/8/11 2:17
From Perth
The paint that I am using is called NOMIX. Does anyone know what I can use to Primer/Sealer it??
Posted on: 2007/8/11 2:23
From Brisvegas, oz
why not just get it sprayed properly to start with?
Posted on: 2007/8/11 2:53
www.camerasplus.com.au
From Perth
Because im not made of money.
Theres loads of rust that needs repairing and the quotes that I get from sprayshops are too expensive.
Otherwise yes I would chuck it into a sprayshop and say "make it look good"
Posted on: 2007/8/11 3:30
From 6065
hell no! dont you even think of using acrylic,that stuff dosent last these days,it'll look like a flakey vl commodore in no time! use a catalysed clearcoat that complies with the colour coat brand. spend some time sanding back the house paint(ugggh) til its all gone.do the bodywork weld,bog,etc.finish with 180grit.primer it and guide coat with flat black(even a spraycan will do).block it out with 600wetdry then 800wetdry.then layer that phantom blue on real nice,clear it and hey presto youre rollin in style again....
Posted on: 2007/8/11 13:58
From Wagga Wagga
terps!
Posted on: 2007/8/11 14:05
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
hyfill will blend uneven surface and give u a thick base to sand....
maybee give that ago
but i aint a smash repair so dont quote me.lol.
Posted on: 2007/8/11 17:02
From NSW, Australia
o.k here goes Retal052. as posted earlier, get rid of that house paint either rub it out or as i would do paint strip it firist!!.
This will show you and hidden suprises under all that sh!t too. I only recommend acrylic if it is a solid paint as you said you dont have much $$$. Just put heaps of coats on so you can rub back any orange peel and buff it flat and shiney, but like K-DOGG mentioned acrylic doesnt look the best in metalic.
Also with primer if your going to leave it on for a while use a guide coat as this will help with soaking moisture.
I hope this helps, post some pics when you paint the beast!! Good luck
Posted on: 2007/8/11 23:22
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
From Sunshine Coast, Queensland
hey demo whats the go with this 'hyfill' stuff shortly to repaint my ute which some boofhead put house paint on then left it in the padock...eeerrr wonder y its more cracked up then a five year old on happy gas!
Posted on: 2007/8/12 0:18
