Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#21
Re: Fuel line.....fuel setup....... questions/advice
mikgan
Posted on: 2007/8/13 22:08
Wow I was thinking I was up for another couple o hundred bucks, so anything shy of that is a bonus.
#22
Mildman
Posted on: 2007/8/13 23:26
Between $10 & $15/metre for 3/8, about $10 or less / metre for 5/16"
I payed $13 a metre for 3/8" bundy tube. It comes in lengths of 6 metres....so I just got all 6 to save them cutting it. Comes in a hoop around a metre in diameter....so not too hard to roll straight.
#23
1200rallycar
Posted on: 2007/8/13 23:29
pirtek obviously does it different, they cut mine from a straight section to the length i wanted (prob only 3-4 meters)
i spose the coil is handy if you dont have a hatchback to get it home
#24
Demo
Posted on: 2007/8/14 13:17
i was gonna run hard line through tunnel
rubber hose from tunnel to reg rub hose from tunnel to surge no bends etc..etc.. or i might bend up at engine bay and conect straight to reg.... should i run the same size line for return??? What fixxing clamps should i use ??? or will pirtec have em...
#25
Mildman
Posted on: 2007/8/14 19:51
I've gone one size smaller on the return line, so 3/8 (10mm) feed, 5/16 (8mm) return.
That's the plan anyway - still waiting to hear from CAMS on the rear firewall requirement.....I think I might need one.
#26
Demo
Posted on: 2007/8/14 22:34
where did u run hard line 2
i plan to only hardline through the tuneel and rubber hosses from there to engine and surge
#27
Mildman
Posted on: 2007/8/15 8:15
Get the steel fuel line as close as you can to the reg, surge, engine connections and yeah just run rubber hose from there.
