« 1 2 (3)
Re: Fuel line.....fuel setup....... questions/advice
Quite a regular
Wow I was thinking I was up for another couple o hundred bucks, so anything shy of that is a bonus.
Posted on: 2007/8/13 22:08
From SE Melbourne
Between $10 & $15/metre for 3/8, about $10 or less / metre for 5/16"
I payed $13 a metre for 3/8" bundy tube. It comes in lengths of 6 metres....so I just got all 6 to save them cutting it.
Comes in a hoop around a metre in diameter....so not too hard to roll straight.
Posted on: 2007/8/13 23:26
Mildman, Datsunless
From Melbourne, Australia
pirtek obviously does it different, they cut mine from a straight section to the length i wanted (prob only 3-4 meters)
i spose the coil is handy if you dont have a hatchback to get it home
Posted on: 2007/8/13 23:29
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
i was gonna run hard line through tunnel
rubber hose from tunnel to reg
rub hose from tunnel to surge
no bends etc..etc..
or i might bend up at engine bay and conect straight to reg....
should i run the same size line for return???
What fixxing clamps should i use ???
or will pirtec have em...
Posted on: 2007/8/14 13:17
From SE Melbourne
I've gone one size smaller on the return line, so 3/8 (10mm) feed, 5/16 (8mm) return.
That's the plan anyway - still waiting to hear from CAMS on the rear firewall requirement.....I think I might need one.
Posted on: 2007/8/14 19:51
Mildman, Datsunless
where did u run hard line 2
i plan to only hardline through the tuneel
and rubber hosses from there to engine and surge
Posted on: 2007/8/14 22:34
From SE Melbourne
Get the steel fuel line as close as you can to the reg, surge, engine connections and yeah just run rubber hose from there.
Posted on: 2007/8/15 8:15
Mildman, Datsunless
« 1 2 (3)
