« 1 2 (3)
Re: considering L series swap
From southern sydney "the shire"
So there are a few changes:
Engine / Crossmember = L18/180B (trimed)
Gearbox / Crossmember = L series gearbox / 180B crossmember
Brakes ect = complete 180B front end i.e. struts, LCA, tie rods, 120y sway bay ect...
Radiator180b radiator
Clutch Peddle = hydrolic clutch using the original 120y and clutch master and slave cylinder out of the 180B.
Tail Shaft = Still not sure. Either 180b one piece or bluebird
Diff = 120y BW diff
What is the advantage of using a stanza sss/ r30 stumpy gearbox over the standard L series one that comes with the L18?
shirley, why do you recomend that i stick with the 120y sway bar? does it still line up with everything?
Posted on: 2007/8/19 7:24
From Brisbane, Australia
1) If you use the short boxes, you might be able to use a 120Y auto tailshaft.
2) the shifter will come up through the factory hole in the trans tunnel.
I'd rather "trim" the castor rod mounting brackets than the engine x-member.
Posted on: 2007/8/19 7:32
In your photo album you have a pic of a trimmed crossmember. What part do you mean buy trim the castor rod mounting brackets? Are we talking about the same part?
This part?
Posted on: 2007/8/19 7:59
From Geelong, Vic
yes that is the castor rod mounting bracket
Posted on: 2007/8/19 8:03
woops thats what i ment
Posted on: 2007/8/19 11:07
« 1 2 (3)
