hows this for a power option
From ipswich
supercharged 1800.............i have a bmw 1.8l sohc with the option of fuel injection and a eaton m90 supercharger...........opions?
Posted on: 2007/8/23 9:21
datsun 1200 ute
* turbo A-series * mandarin mica paint * flare kitted and air dam front bar
xh ford falcon longreach s pack 302ci
rolls on 4 big round things
Re: hows this for a power option
From Far, far away
Probably a tough fit, but anything can be done.
It would be an original, that's for sure. If you have the time and money go for it.
Posted on: 2007/8/23 10:21
From Adelaide, Australia
Is that out of a 318i? That wouldnt be too hard to fit, they are a 4cyl.
I have a 318i motor and a 320i if you need engine parts.
Im not parting out the 320i
Posted on: 2007/8/23 10:31
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From ipswich
yes its from the 318i. ive measured it all up and it will be a very tight fit. its goin to be a long term project as i will be building the engine up before it goes in. there will be alot of work involed as the motor is on a slant and the booster will have be relocated so i scored the one out of the bemer which has linkages the mount it on the opposite side.
actually i may need spare parts as i have a few broken parts such as the dizzy and housing, water pump and pully and possibly altinator. i will also need to adapt a pully to suit muti v belt for the supercharger
the supercharger is quite a large unit utilising a bypass valve with unfortuanately makes it longer making it more difficult to fit however on the bright side these things can produce something like 14 - 17 psi of boost which ive seen on a supercharged 3.5L v8 mighty boy i was working on last year
Posted on: 2007/8/23 12:55
datsun 1200 ute
From Geelong, Vic
there a slant 4 though arent they, would make it a bit harder to fit
EDIT: so you know it will be hard to fit
surely there would be some better candidates out there if its to be a long term project rather than something just thrown together coz you have the parts
From Newscastle, Australia
what an awful engine to put in such a beautiful car.
Its like a gender reassignment
Posted on: 2007/8/23 13:58
Dont die wondering.....
From ipswich
well i could have just thrown a ca in it but who wasnt done that? there is nothing wrong with this engine its done over 300 thousand k's and it still looks brand new on the inside( apart from carbon deposits), bores still have orignial hone marks
Posted on: 2007/8/24 0:27
datsun 1200 ute
From Bris-Vegas
Those cast iron beemer motor's are heavy as buggery.
I'd imagine similar handling characteristics to a FJ20..... Understeer
Would go alright on the strip though....
What do you want to use it for?
Posted on: 2007/8/24 1:02
CA18DET '74 1200 ute project
From Perth WA
my experience of both the bmw and merc 1.8 efi 4cyl engines is they are thirsty, heavy and noisy even at idle and worse at over 100kmh.
enthusiasts actually do engine swaps the other way round, thats putting nissan SR20's into merc 180E's and bmw 318's to make them move.
Posted on: 2007/8/24 8:22
From Canberra
how much does it cost to build a bmw motor compared to a Nissan or Toyota donk?
Posted on: 2007/8/24 8:34
