« 1 (2)
Re: Bolt patterns for Weber, Dellorto and Solex/Mikuni
From Canberra
hmm doesnt look like you can trim anything there...
Also how does the manifold bolt to the head, I cant see any holes for bolts??
edit: I see its got those weird holes between the ports...
Posted on: 2007/8/30 12:48
There is a hole between the two channels of each 'branch'. Just the two holes.
I'm getting the impression that this is a manifold that isn't popular- for obvious reasons.
I can't file the solex's there is'nt enough to thread onto if I shave it to the dimensions that they need to fit....Arrrgggh.
Posted on: 2007/8/30 12:57
From Townsville, Qld
I thought you could buy a larger single shaft that would go through both carbies? but I'm obviously thinking about the accelorator cable shaft you mount up near the tappet cover
Posted on: 2007/8/30 14:52
Any other suggestions.
Yeah not the external throttle shaft littledarkone but the ones that run through the throats of the carbies.
Edit. Is the manifold even usable? These were sold to me by another member....
Posted on: 2007/8/31 8:26
« 1 (2)
