Bushings interchangeable?
From Mesa, Arizona, USA
Hi all. I have found out that our exterminator guy is also a distributor for Super Pro polyurethane suspension components which, I guess, is based in Australia. He's been checking out my 1200 coupe project sitting in the garage and he left me a catalogue from Super Pro after spraying the house today. My question is, the catalogue only lists bushings for the sedan and utility. Since I have a coupe, what bushings are interchangeable? Could someone let me know from the list below, if they are usable in the coupe?
1.Bump Stop - upper
2.control arm lower - inner bushing
3.idler arm bushing
4.strut bar to chassis mount bushing
5.sway bar link bushing kit
6.sway bar mount to chassis bushing
7.spring front eye bushing (2 different sizes)
8.spring rear eye bushing
9.spring shackle upper bushing
Thanks a bunch!
Posted on: 2007/9/7 3:58
turboron@hotmail.com
If it ain't broke, fix it until it is!!!
Re: Bushings interchangeable?
From Brisbane, Australia
the only one that might be different is the bump stop - assuming that's for the rear? Ute had a different diff.
Posted on: 2007/9/7 4:42
Thanks! that helps. I just want to minimize the possibility of ordering the wrong part. Especially since we can't get parts like that here in the states.
Posted on: 2007/9/7 5:39
I'm guessing the '78 up utes use the larger parts from the B210/610. You might want to verify first.
Posted on: 2007/9/7 6:49
From Castro Valley,CA USA
Is there a website on that catalog?
Posted on: 2007/9/7 7:16
http://www.superpro.com.au
Coupe and Sedan bushings are identical. All 1971-1973 suspension parts are the same, except GX swaybar and swaybar bushing (brackets are the same).
If you have fitted a B210 swaybar, you'll probably want to use the B210 bushings.
Posted on: 2007/9/7 7:23
It looks like they have both 17 and 20 mm swaybar bushings. B110 is 17, B210 is 20mm.
Posted on: 2007/9/7 7:40
