how do i set ca18det cas
Quite a regular
Hey sadly i pulled the cam angle senser out of my ca18 and i need to know how to set it up so all the timings sweet. so far i know set engine at tdc #1,line up all the notches. but i cant just slam the sensor in can i? thanks for your time
Posted on: 2007/9/10 8:54
Re: how do i set ca18det cas
From Christchurch NZ
I think there will be a click when the CAS is at tdc.
Posted on: 2007/9/10 9:00
Forced Induction!
From Sydney, Australia
there is a half moon locator in the end of the cam..if it's missing, or if somebody decided to use 2 intake cams..you are in trouble.
The fine tuning of the CAS is done with a timing light, the workshop manual and a 10mm spanner.
Posted on: 2007/9/10 9:32
Quite a regular
lol thanks. so if its thea obviously just bolt in when at the tdc. if it not thea on the cas then buy another? thanks
Posted on: 2007/9/10 10:22
From SE Melbourne
Yep, it should only fit in one way....
Posted on: 2007/9/10 10:26
Mildman, Datsunless
From Melbourne Vic
doesn't need to be at TDC, just put it back in the only way it goes in. then set your timing with a timing light. 15 degrees if i remember correctly...
Posted on: 2007/9/10 11:47
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Quite a regular
thanks guys i appreciate all the help. Will put it in nd see how the beast goes. cheers
Posted on: 2007/9/11 9:06
