Re: T series gearbox for the a series
Quite a regular
From Finland
Interesting. Dat141, so u just used the standard 56 series gearbox (clutch housing) for the modification? Do u possibly have photos of that operation??
What makes this conversion not roadworthy? Do u think that it would be possible to use some more time and effort to make it roadworthy?
Which T50 did u use? (from which toyota)
Posted on: 2007/9/9 11:39
From Perth Western Australia
I've seen a few posts on here mentioning that the E Series motors have a very similar bellhousing to the A series with possibly minor modification to make them fit - was the E series engine available in Finland perhaps with an Auto gearbox? perhaps thats where you can get your AT bellhousing.
just a thought hope it helps
Posted on: 2007/9/10 3:19
Datsun 1000 it's
All-round Action!
Thou Coupe worked A14 twin bbq's
Quite a regular
From Finland
Thanks kue1000. I could find one E-series autobox on sale right away (N13, B12 'over there'?). Though its gonna be too expensive to buy for this conversion. Maybe I can find a broken one.
Does anybody know the type of that gearbox (like T50) that I could search for photos of it?
My current idea is to make the clutch housing out of standard gearbox and connect it to toyo gearbox by using flanges.
Here is an exploded view for people who have not seen how T50 looks like:
T50
Posted on: 2007/9/10 8:42
This is the only photo i have of my T50 before it was installed but it shows the new bellhousing.
Posted on: 2007/9/11 5:05
Datsun 1000 it's
All-round Action!
From Coondle, WA Australia
Heya Kue
Did you have to use that spacer plate thing between the adaptor and the block, or does the adaptor take that space up?
Posted on: 2007/9/11 10:46
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Quite a regular
From Finland
Thanks for the photo kue1000. Which bellhousing is that?
thanks
Tuukka
EDIT: I guess its the dellow one... since u have dellow manual/catalogue there...
Posted on: 2007/9/11 12:45
From Southern Highlands, NSW, Australia
I'll try and remember to take some photos next time the gearbox is out of the car. There are probably easier ways to convert a T50 into a 1200 but we just used what we had lying around, and it only cost around $250 for the tailshaft and the new clutch plate.
Posted on: 2007/9/12 1:51
'72 1200 sedan hillclimb/supersprint car
N13 is N13 'everywhere'. B12 likewise.
The problem is some countries called certain N-series (Pulsar family) vehicles a Sunny, and others called some B-series (Sunny family) a Pulsar. Better to use the chassis code N13 and B12 -- then we know exactly what you mean.
Posted on: 2007/9/12 5:15
Quite a regular
From Finland
dat141, it would be great to have some photos.
I found this topic a couple days with pictures of similar conversion. TnPshow had a problem that the input shaft did not stick out far enough after the conversion-> clutch problem
Dat141, do u have any measurements of the conversion u did? It would be great to know the distance from the 'front of the bellhousing' to spot where the bellhousing bolts on. Then I would have some kind idea that what kind of space the clutch requires to function properly.
thanks once again
Tuukka
I got this info from Dellow automotives today:
January 2007
TOYOTA 2T OR 3T 5-SPEED BEHIND DATSUN
Posted on: 2007/9/12 17:49
There seems to be a few pics searching dellow but none of them are IN the cars!
Anyone got any pics of these installed? Are the mounts included with the kit? (Wiki sez you have to remove the existing mounts)
Posted on: 2009/4/5 11:35
« 1 2 (3) 4 »
