Front Apron/Bar Removal
Quite a regular
I want to paint the front radiator support and to do that I need to remove the front lower apron/spoiler. It seems to be welded on. Is this correct on all models or was mine modified in a way. What is the best way of removing the welds without damaging anything
Posted on: 2007/9/11 22:20
Re: Front Apron/Bar Removal
From Geelong, Vic
they are all welded on, best way to remove it is by getting rid of the spot welds that hold it on
do this using a spot weld drill bit of a die grinder
Posted on: 2007/9/12 3:20
Quite a regular
And it is best to use a MIG Welder to put it back on?
Posted on: 2007/9/12 22:08
From Geelong, Vic
yeah mig would be a good way to reattatch it, although im just making mine bolt on so its easy to get off again if need be
as it already has a nice bolt hole on either side at the top for attatching it
Posted on: 2007/9/13 2:11
Quite a regular
got any pics of how it looks with all the holes in the lip? I had a look at that one the other week and there was a butt load of welds to bust, having said that yer its the only way to get it off.
Posted on: 2007/9/13 4:21
Quite a regular
It seems most of the bottom of the apron is spot welded on. Am I mean't to bog up the holes when it drill out the spot welds?
Posted on: 2007/9/25 0:24
From Geelong, Vic
you only make holes in the front apron, then weld them up when you re attatch it
Posted on: 2007/9/25 0:40
From Brisbane, Australia
1. Centre Punch and Spotweld Drill
2. Drill through the first layer
3. Remove first Layer
The spot weld drill is basically a flat cutter with a tiny centre drill.
Posted on: 2007/9/26 0:35
