#1 Converting 4 door 1200 sedan to 2 door (photochop pics)
Poco Posted on: 2007/9/17 11:23
Hi all, has anyone converted a 4 door 1200 to 2 door?
I know some of the 1600 guys have done it but it looks a bit wonky, i did a quick photoshop on these two 1200 sedans and it looks pretty good?
Ultimately i would like to weld up the rear doors on a sedan and add the coupe flares (it's a race car).
It almost looks like the original 2 door sedan, just not as curvy, but still well proportioned.
#2 Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
1200rallycar Posted on: 2007/9/17 11:25
"go_the_datto" did it, check out his pictures and link
#3 Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
TnPshow Posted on: 2007/9/17 12:52
You're right the 510's converted look a bit odd but the 1200 looks great like that!
If you're doing a racecar then remove the 2 piece windows and replace them with 1 piece perspex
#4 Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
beattie Posted on: 2007/9/17 13:32
What about moving the B pillar back and using like Coupe doors(assuming they are longer like a thou)?
#5 Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
PIGDOG Posted on: 2007/9/17 13:46
that would actually make it very very close to the real thing seems as the 2 doors use coupeish doors(with different tops)
#6 Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
1200post Posted on: 2007/9/18 10:43
The 1200 post is shorter than a 1200 sedan this you must consider when building your toy
#7 Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
1200rallycar Posted on: 2007/9/19 12:24
2dr sedan door skins are diffrent to coupe skins
#8 Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
dazzasute Posted on: 2007/9/19 13:04
not quite that simple... as mentioned before, the tops of the doors are different, which means you would have to extend some standard 1200 door tops, and put them onto coupe doors... Then you'd find the glass will be different, and neither coupe glass or standard sedan glass will fit, and probably not even standard 1200 2 door sedan glass.... You'd have to get custom... I s'pose its not that bad since glass in 1200's is straight!
Don't let me put you off though, go for it
#9 Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
cheater_5 Posted on: 2007/9/19 20:52
2dr is a lil more roundey in the rear window too
#10 Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
ddgonzal Posted on: 2007/9/20 0:25
Sure, everything has been done before:
Tudor 1200s
