Rust
Quite a regular
From Sydney, Australia
Hey there Guys and Girls,
Ok im quite new to dattos so im just inquiring about a bit of rust in my 1200 sedan on the join between the firewall and engine bay. and also around the rear wheel arches. how much would this be to fix?ect... what should i do? thanks in advance for your help
Fitzy
Posted on: 2007/9/18 8:26
Re: Rust
From sydney/gold coast
can u post some pics and i can quote it i am a panel beater
Posted on: 2007/9/18 8:41
Re: Rust
From Perth Western Australia
you mean like this?
I fixed mine up myself. Not the easiest job, but if you can drive a grinder and a welder ok, and have some experience welding sheet metal you should be ok. Otherwise get some one to do it for you.
Here's my repair job:
cut it out
cut it out some more, and weld up the first two bits
weld it up
Not hard if you have the patience/skills/tools.
As for the back, there's a lot less margin for error there. If you mess it up, you'll see it every time you look at your car, as a pose to this, you only see it when you look in the corner of the engine bay. Still, if you're determined to do it yourself, it works pretty much the same way. Just watch out that excess heat doesn't warp the panels and make it worse warpings not hard to do...
Posted on: 2007/9/18 8:52
Re: Rust
im also in sydney if that helps
i wouldnt reccomend doing it yourself it needs to be sealed properly etc
Posted on: 2007/9/18 9:08
Re: Rust
From southern sydney "the shire"
how is this for rust commitment
Posted on: 2007/9/19 0:00
Re: Rust
From Bris-Vegas
My Car....
Before: -
And after: -
I swear.... Never again!
Posted on: 2007/9/19 4:39
CA18DET '74 1200 ute project
Re: Rust
From Sunshine Coast, Queensland
hey the top picture looks just like mine atm wait a minute no theres not enough rust one day it will be done...one day.
Posted on: 2007/9/19 7:01
75 datto ute - now selling
73 datto sedan - now building
simmos NEW ute build
Re: Rust
Quite a regular
thanks for the help guys. ill try and get photos. im just in denial of painting...what a pain in the ass:P
Posted on: 2007/9/19 9:18
