what exedy clutch number to use for an A15
From bathurst nsw
ive got the two clutch kit part numbers
nsk-6121hdcb (for A12 and recomended by the exedy bloke i talked to)
and
nsk-6147hdcb (suited to an A15 vannette.)
both use the same clutch disk nsd-029u (which is the part number i got off of the clutch disk in my car, and it is also the same in the exedy books) but they are different housings i suppose???????
so does anybody have the right kit number for the A15 that they have used
or have a recomendation for the grade of clutch to use. i am going for the heavy duty cusioned button ceramic clutch (hdcb sufix) for my 109hp A15 racecar as i burnt the clutch out this weekend at the nsw supersprint championships at wakefield park
any help would be appreciated
thanks kurt
Posted on: 2007/9/18 8:17
My car gets me from A to B...Just faster ;)
Re: what exedy clutch number to use for an A15
From Geelong, Vic
i actually got the part numbers today, but dont remember what they were
i know 1200 was the same as sunny, which were different to 1000
Posted on: 2007/9/18 10:34
From Brisbane, Australia
Go for the Vanette one. The pressure plate should have a higher clamping force.
those part numbers look very foreign, but it has been a couple of years since I've bought an A series clutch. Daiken (aka Exedy) R169HD is the part number I know for the Heavy Duty Vanette clutch. I've used one of these behind a very strong A14 turbo engine.Thait was full face rather than sprung button plate though. That's obviously the extra "cb" suffix on the part number.
Posted on: 2007/9/18 12:04
From Geelong, Vic
the part numbers in the first post look like the ones i saw, if getting a HD just get them to make it as heavy as they can
shouldnt cost anymore and can go a fair bit more than the normal HD im pretty sure
Posted on: 2007/9/18 12:06
From bathurst nsw
the hd stands for heavy duty
hdb stands for heavy duty button
hdcb stands for heavy duty cushion button clutch
the hdcb gives a smoother engagement insted of the in or out style of the button clutch.
has anybody put one of these clutches on their A15?
Posted on: 2007/9/18 12:18
From bathurst nsw
bump
Posted on: 2007/9/19 9:17
