#1 Advice on 120Y strut insert options.....
Coops Posted on: 2007/9/19 4:44
Starting work on the 1st stage of my front suspension upgrade this w'end.
Going to try cut down Gemini coils as suggested.
The 120Y struts are staying at stock length & ride height (for the time being)
Can anyone suggest a good quality shock insert?
A part or model no. would be $hit hot.
Thanks in advance,
Coops
#2 Re: Advice on 120Y strut insert options.....
Team_Dat Posted on: 2007/9/19 6:12
KYB 362001 fronts
#3 Re: Advice on 120Y strut insert options.....
cheater_5 Posted on: 2007/9/19 7:27
are they shorter than standard? and does anyone know if 120y and b110 shocks are same length standard
#4 Re: Advice on 120Y strut insert options.....
Team_Dat Posted on: 2007/9/19 7:36
that part number is a standard replacment shock from KYB. not sure on 1200 interchangability
#5 Re: Advice on 120Y strut insert options.....
Coops Posted on: 2007/9/19 9:34
Thanks for that.
I was just thinking I probably should be doing rear shockies at the same time.......
You don't by any chance have the KYB part no for 1200 ute rear shocks?
