need help to fix clucth resovir thing ( maddat boster)
From perth airport
ok guys i have a datsun 1200 ute wit a ca18det useing all maddat stuff crossmember and brake booster, the clucth resovir it hitting the inlet manifold . the best way to fix it would be to get a new plastic fulid holder (resovir ) . the plastic resovir that came wit the kit it taper so its small at the bottom then big at the top ....the top is hittting :( if i had one made so it didnt taper it would work great :) wat could i make it out of alloy ?? or do they have to be plastic?? thank for reading and any help is great regards jordan Open in new window
Posted on: 2007/9/19 3:14
perth airport parking
Datsun 1200 ute A14
Re: need help to fix clucth resovir thing ( maddat boster)
From perth airport
a nother pic of the plastic resovir
it a top view and you can see its not round anymore coz it hitts the inlet manifoild Open in new window
Posted on: 2007/9/19 5:24
Datsun 1200 ute A14
From Perth W.A
you can get caps that go over the top that have a hose to the actual resivoir, they use that system on the vanette brake MC, i don't see why you wouldn't be able ot get something like that to fit to the clutch... ask either maddat or datsport or similar they would have a solution or the item i'm talking about.
Posted on: 2007/9/19 7:24
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Adelaide
Hey Jordan, Give me a call, somthing is not right somewhere if it is hitting the reservoir. It should clear by about 15mm.
Cheers Scott
Posted on: 2007/9/19 8:57
From perth airport
thanks scott ill ring a bit later in the morning
i did talk about this wit craig a while back but we could nt find a solution
Posted on: 2007/9/19 23:28
Datsun 1200 ute A14
